We want to hear your ideas for improving JMP software.
  1. Search: Please search for an existing idea first before submitting a new idea.
  2. Submit: Post your new idea using the Suggest an Idea button. Please submit one actionable idea per post rather than a single post with multiple ideas.
  3. Kudo & Comment Kudo ideas you like, and comment to add to an idea.
  4. Subscribe: Follow the status of ideas you like. Refer to status definitions to understand where an idea is in its lifecycle. (You are automatically subscribed to ideas you've submitted or commented on.)
We consider several factors when looking for what ideas to add to JMP. This includes what will have the greatest benefit to our customers based on scope, needs and current resources. Product ideas help us decide what features to work on next. Additionally, we often look to ideas for inspiration on how to add value to developments already in our pipeline or enhancements to new or existing features.
Heatmap + Data filter: speed up the graph generation
☐ cool new feature
☐ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
heatmaps get built without local filter applying and after it is ready local data filter is applied
If a large data set is used which can just be displayed with a local data filter applied, the generation of the Heatmap Plot will take minutes.
Please solve this issue.
clever/dirty workaround: start with points and switch to Heatmap after jmps applied the data filter.
speeding up heatmap graphs?
3 Comments
danschikore
Hi @hogi - thank you for this suggestion.  When you have a chance to try JMP 17, I would suggest testing your original script again.  Many platforms have been updated to use the filtered data view on the first launch, rather than running with the full data and then filtering down.  Not all platforms can do this, because some platforms terminate early if there is not enough data to analyze.  Graph Builder definitely benefits from this change in JMP 17, so I hope you will see your scripts running faster without requiring a workaround.
-Dan
hogi
Level XI
you are right, the issue is gone.
Thanks a lot
-> wish can be closed
Jeff_Perkinson
Community Manager
Status changed to: Delivered
