%3CLINGO-SUB%20id%3D%22lingo-sub-54017%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMit%20einer%20JMP-Startschaltfl%C3%A4che%20im%20Abfrage-Generator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-54017%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDie%20meisten%20von%20JMP%20verwendeten%20Tabellen%20haben%20das%20magische%20JMP-Home-Button-Symbol%20unten%20rechts%20in%20der%20Tabelle%2C%20mit%20dem%20Sie%20zum%20Home-Fenster%20zur%C3%BCckkehren.%20Ich%20benutze%20den%20Abfrage-Generator%20h%C3%A4ufig%20und%20wenn%20ich%20eine%20Reihe%20von%20JMP-Anwendungen%20ge%C3%B6ffnet%20habe%2C%20kann%20es%20ziemlich%20schwierig%20sein%2C%20herauszufinden%2C%20welche%20die%20Abfrage%20sowie%20alle%20anderen%20von%20mir%20verwendeten%20Tabellen%20enth%C3%A4lt.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EKann%20die%20Schaltfl%C3%A4che%20des%20JMP-Startfensters%20zum%20Abfrage-Generator%20hinzugef%C3%BCgt%20werden%20(sowie%20zu%20allen%20anderen%2C%20die%20sie%20derzeit%20nicht%20haben)%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-54017%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EBenutzeroberfl%C3%A4che%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Having a JMP Home Button On Query Builder
Most of the tables that JMP uses have the magic JMP Home Button icon bottom right of the table which takes you back to the Home Window . I use the Query builder a lot and if I have a number of JMP applications open it can be quite tricky to find which one contains the query as well as any other tables I'm using.
Can the JMP Home window button be added to the Query Builder ( as well as any others not currently having it)?
David
