Have an option to connect the first and last point using the Line element in Graph Builder
I've been using the "Row Order" ability in Graph builders Line element to make Spider Plots and Spline Fits.  This works great with the exception of the there being a gap between the first and last item.
I would like to see the option to have the last and first row connected when you click the "Row Order" button.  This could just be a check the box item right below it.  So "Row Order" then "Connect First/Last Points"
Why is this idea important?
This removed the need to script in finding the first point and adding a duplicate row to make the Line fit all the data
2 Comments
hogi
Level XIII
ah, good point.
Somehow the inverse issue of:
Graph Builder: Line - possibility to add breaks
Combining both wishes, JMP developers might say: on average there is nothing to do ; )
For both issues, there is a similar workaround:
add "dummy rows" to the data set to tune the plot.
Sarah-Sylvestre
Level V
Thank you for submitting this request!
