  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Graph Builder: polar plot
☑ cool new feature
☐ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
Add polar plot as an option to GraphBuilder.
many other plotting tools have such an option:
https://www.mathworks.com/help/matlab/creating_plots/plotting-in-polar-coordinates.html
https://reference.wolfram.com/language/ref/PolarPlot.html
To keep the GraphBuilder Interface as it is, one could "hide" the polar plot mode under Scale Type - similar to Geodesic, where an even more complicated projection is used to convert the coordinates to x/y values.
The idea:
The user selects R and Phi values for the X and Y axis and selects polar plot in one of the Scale Type menus (the other Scale Type is changed automaticaly).
As a result, the values are converted to x/y coordinates and a polar grid is used.
Alternative - if this is not possible:
The user directly loads x/y coordinates and selecting polar plot from the Scale Type menu.
This changes the grid to r/phi.
Difficulty: how to define the major/minor grid steps?
3 Comments
hogi
Level XIII
I just noticed that there is another wish with a simlar title: Polar-plots/idi-p/147599
Both wishes are independent, because they ask for different types of plots.
Definitely, there is a lot in common:
- values are arranged in a circular way
- one variable is  used as "radius"
But there are significant differences:
- Polar-plots/idi-p/147599 asks for a Radar Plot / Kiviat Diagram:
where an arbitrary number of discrete categories/ratings are arranged in a circle instead of a normal x/y line chart.
The wish here asks for a polar plot where the second variable besides radius is the angle phi, which runs from 0 to a final value (e.g. 180°, 360°, > 360°)
examples of polar plots in other statistical/plotting tools:
https://www.medcalc.org/manual/polarplot.php
https://www.mathworks.com/help/matlab/ref/polarplot.html
https://www.wolframalpha.com/input/?i=polar+plot
https://octave.sourceforge.io/octave/function/polar.html
A polar plot could look like a Kiviat diagram, but it doesn't have to:
It is used when a value depends on an angle. Then the value is plottet as radius versus angle.
This makes it much easier to understand the dependency:
Mathematica uses PolarPlot to plot the dependent variable (radius) versus the independent variable (angle) - but doesn't show the radial, angular grid.
I hope that Jmp will do better :)
Sarah-Sylvestre
Level V
Hi @hogi, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
hogi
Level XIII
ancestor of this wish: Radiation pattern
