Graph Builder Transparency and Color Picker on PC
#1 There needs to be a way to export graphs with transparent backgrounds. I am trying to get my colleagues to switch to using JMP for generating figures and one of the main places I get pushback is "JMP graphs are ugly." I have strategies for making them look better but needing to change the background color RGB for multiple box layers is prohibitively burdensome. The obvious solution is to be able to export graphs with transparent backgrounds.
#2 I had to switch to a PC for work and was devastated to learn that the PC version of JMP does not have a color picker feature. I am colorblind and being able to match colors from my screen saved me a very significant amount of time vs. needing to google RGB then type it in every time I want to match the colors for a presentation.
#1 - Transparent backgrounds for Graph Builder
#2 - A color picker feature for PC
Why is this idea important?
These minor changes would make my job easier on a daily basis. They would also make it easier for me to convince people to use the software.
1 Comment
@Genentech_Ben , thank you for your request. We will investigate this internally.
