  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
%3CLINGO-SUB%20id%3D%22lingo-sub-803138%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EGenerador%20de%20gr%C3%A1ficos%3A%20opci%C3%B3n%20para%20ocultar%20categor%C3%ADas%20sin%20datos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-803138%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ETenemos%20el%20mismo%20problema%20o%20necesidad%20que%20se%20describe%20en%20esta%20pregunta%20de%20la%20Comunidad%20de%20usuarios%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FGraph-Builder-hide-X-categories-with-no-data%2Fm-p%2F209809%22%20target%3D%22_blank%22%3EResuelto%3A%20Graph%20Builder%3A%20ocultar%20X%20categor%C3%ADas%20sin%20datos%20-%20Comunidad%20de%20usuarios%20de%20JMP%3C%2FA%3E%20.%20Aqu%C3%AD%20se%20resuelve%20mediante%20scripts%2C%20pero%20ser%C3%ADa%20mucho%20mejor%20y%20m%C3%A1s%20flexible%20tener%20una%20soluci%C3%B3n%20interactiva.%3C%2FP%3E%3CP%3EEl%20generador%20de%20gr%C3%A1ficos%20siempre%20muestra%20todas%20las%20categor%C3%ADas%20en%20el%20eje%20x%2C%20y%20a%20veces%20eso%20est%C3%A1%20bien%2C%20pero%20en%20otras%20situaciones%20no.%20S%C3%A9%20que%20no%20hay%20datos%2C%20por%20ejemplo%2C%20esta%20medici%C3%B3n%20en%20particular%20no%20se%20realiz%C3%B3%20para%20todos%20los%20lotes.%20Por%20lo%20tanto%2C%20no%20quiero%20ver%20los%20lotes%20que%20no%20tienen%20medici%C3%B3n%20en%20el%20eje%20x.%20Esto%20se%20puede%20resolver%20agregando%20un%20Where%20al%20script%20del%20generador%20de%20gr%C3%A1ficos%2C%20pero%20no%20todos%20conocen%20JSL.%20Y%20si%20tambi%C3%A9n%20queremos%20usar%20un%20conmutador%20de%20columnas%20(como%20en%20la%20pregunta%20de%20la%20comunidad%20de%20usuarios)%2C%20se%20requiere%20mucho%20JSL.%20Consulte%20Example1.jmp.%3C%2FP%3E%3CP%3EEl%20comportamiento%20predeterminado%20del%20generador%20de%20gr%C3%A1ficos%20tambi%C3%A9n%20es%20un%20problema%20cuando%20se%20utiliza%20la%20p%C3%A1gina.%20Por%20ejemplo%2C%20tenemos%20mediciones%20para%20muchos%20lotes%20de%20diferentes%20f%C3%A1bricas.%20Utilizo%20la%20medici%C3%B3n%20como%20Y%2C%20el%20lote%20como%20X%20y%20la%20f%C3%A1brica%20como%20p%C3%A1gina%20y%20lo%20convierto%20en%20un%20gr%C3%A1fico%20de%20barras.%20El%20eje%20x%20muestra%20todos%20los%20lotes%2C%20lo%20que%20significa%20que%20la%20mayor%20parte%20de%20cada%20gr%C3%A1fico%20es%20un%20espacio%20vac%C3%ADo%2C%20mientras%20que%20me%20gustar%C3%ADa%20que%20solo%20mostrara%20los%20lotes%20donde%20hay%20datos%2C%20es%20decir%2C%20los%20lotes%20para%20esa%20f%C3%A1brica%20en%20particular.%20Consulte%20Example2.jmp.%20Actualmente%20resuelvo%20esto%20cambiando%20la%20p%C3%A1gina%20a%20Por%2C%20pero%20luego%20perdemos%20muchas%20propiedades%20agradables%20que%20vienen%20con%20la%20configuraci%C3%B3n%20de%20la%20p%C3%A1gina.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EUna%20configuraci%C3%B3n%20(la%20actual%20puede%20ser%20la%20predeterminada)%20como%20%22Ignorar%2FOmitir%20valores%2Fcategor%C3%ADas%20del%20eje%20x%20sin%20datos%22%20que%20se%20puede%20seleccionar%20de%20forma%20interactiva%20en%20el%20generador%20de%20gr%C3%A1ficos.%20Podr%C3%ADa%20estar%20en%20la%20configuraci%C3%B3n%20del%20elemento%20de%20barra%20si%20no%20se%20aplica%2Ftiene%20sentido%20para%20otros%20elementos%20del%20gr%C3%A1fico.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EPara%20evitar%20gr%C3%A1ficos%20con%20mucho%20espacio%20vac%C3%ADo%20que%20imposibiliten%20ver%20las%20tendencias%20que%20realmente%20buscamos%20y%20evitar%20tener%20que%20hacer%20soluciones%20alternativas.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-803138%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-804766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Graph%20Builder%3A%20Opci%C3%B3n%20para%20ocultar%20categor%C3%ADas%20sin%20datos%20-%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-804766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGracias%20a%20MTOF%20por%20publicar%20esta%20sugerencia.%20No%20estoy%20seguro%20de%20si%20esto%20te%20resulta%20%C3%BAtil%2C%20pero%20este%20tipo%20de%20gr%C3%A1fico%20que%20aparece%20a%20continuaci%C3%B3n%20es%20posible%20en%20el%20generador%20de%20gr%C3%A1ficos.%20Transmitir%C3%A9%20esta%20sugerencia%20para%20incluirla%20en%20la%20encuesta%20de%20priorizaci%C3%B3n%20de%20la%20lista%20de%20deseos.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SarahGilyard_0-1728571064187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SarahGilyard_0-1728571064187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SarahGilyard_0-1728571064187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SarahGilyard_0-1728571064187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SarahGilyard_0-1728571064187.png%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fskins%2Fimages%2FF1980D6F7B4637008110509A6420473D%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20alt%3D%22SarahGilyard_0-1728571064187.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-804778%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERe%3A%20Graph%20Builder%3A%20Opci%C3%B3n%20para%20ocultar%20categor%C3%ADas%20sin%20datos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-804778%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EHola%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F2319%22%20target%3D%22_blank%22%3E%40MTOF%3C%2FA%3E%20%2C%20a%20menudo%20es%20la%20combinaci%C3%B3n%20de%20valores%20en%20el%20eje%20x%20y%20%3CSTRONG%3Eel%20grupo%20X%3C%2FSTRONG%3E%20o%20%3CSTRONG%3Ela%20p%C3%A1gina.%3C%2FSTRONG%3E%3CBR%20%2F%3E%20Por%20favor%2C%20%C3%A9chale%20un%20vistazo%20a%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FX-group-restrict-the-values-on-the-axis-to-the-respective-group%2Fm-p%2F542325%23U542325%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%3Afolded_hands%3A%3C%2Fimg%3E%20Grupo%20X%3A%20restringe%20los%20valores%20del%20eje%20al%20grupo%20correspondiente%3C%2FA%3E%20.%20Ha%20acumulado%20Kudos%20durante%202%20a%C3%B1os%20y%20tiene%20el%20estado%20%22En%20investigaci%C3%B3n%22.%3CBR%20%2F%3E%20Cualquier%20Kudo%20adicional%20aumentar%C3%A1%20la%20posibilidad%20de%20que%20el%20problema%20se%20solucione%20en%20JMP19...%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20Acabamos%20de%20realizar%20una%20encuesta%20en%20nuestra%20empresa%3A%20%C2%BFqu%C3%A9%20limitaci%C3%B3n%20de%20JMP%20es%20la%20que%20m%C3%A1s%20perjudica%3F%3CBR%20%2F%3E%20y%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FX-group-restrict-the-values-on-the-axis-to-the-respective-group%2Fm-p%2F542325%23U542325%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%3Afolded_hands%3A%3C%2Fimg%3E%20Grupo%20X%3A%20restringe%20los%20valores%20en%20el%20eje%20al%20grupo%20respectivo%3C%2FA%3E%20que%20fue%20el%20claro%20%22ganador%22.%3CBR%20%2F%3E%20Como%20mencion%C3%A9%20en%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FCommunity-Wish-List%2FWish-list-new-Label-user-experience%2Fm-p%2F709540%23U709540%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3ELista%20de%20deseos%20-%20nueva%20etiqueta%3A%20experiencia%20de%20usuario%3C%2FA%3E%20%3CSPAN%3E%2C%20muchas%20caracter%C3%ADsticas%20nuevas%20e%20interesantes%20ahora%20se%20pueden%20implementar%20f%C3%A1cilmente%20en%20JMP%2C%20mediante%20un%20desv%C3%ADo%20a%20trav%C3%A9s%20de%20Python%20o%20R.%3CBR%20%2F%3E%20Pero%20cuando%20falta%20una%20funci%C3%B3n%20en%20GraphBuilder%2C%20duele.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-804781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Graph%20Builder%3A%20Opci%C3%B3n%20para%20ocultar%20categor%C3%ADas%20sin%20datos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-804781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPara%20Page%2C%20el%20soporte%20de%20JMP%20sugiere%20esta%20soluci%C3%B3n%20alternativa%3A%3C%2FP%3E%3CP%3Ela%20columna%20que%20se%20utiliza%20para%20la%20p%C3%A1gina%3A%20%C3%BAsela%20adem%C3%A1s%20en%20el%20EJE%20X%2C%20como%20un%20nivel%20adicional%20(como%20en%20el%20ejemplo%20de%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F54402%22%20target%3D%22_blank%22%3E%40SarahGilyard%3C%2FA%3E%20).%3CBR%20%2F%3E%20Con%20la%20p%C3%A1gina%2C%20el%20usuario%20puede%20especificar%20el%20rango%20para%20cada%20subparcela%2C%20para%20mostrar%20solo%20las%20regiones%20que%20no%20est%C3%A1n%20en%20blanco.%3CBR%20%2F%3E%3CBR%20%2F%3E%20...%20lleva%20un%20tiempo%20y%20es%20peligroso%20si%20se%20agregan%20categor%C3%ADas%20adicionales%2C%20pero%20funciona.%3CBR%20%2F%3E%20Para%20%3CSTRONG%3Eel%20Grupo%20X%3C%2FSTRONG%3E%20%2C%20no%20existe%20soluci%C3%B3n%20alternativa.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Graph Builder: Option to hide categories with no data
We have the same issue/need as described in this User Community question: Solved: Graph Builder: hide X categories with no data - JMP User Community. Here it is solved by scripting, but I would be much better and more flexible to have an interactive solution.
The Graph Builder always shows all categories on the x-axis, and sometimes that is fine, but in other situations it is not. I know there is no data, e.g. this particular measurement wasn't done for all batches. So I don't want to see the batches that have no measurement on the x-axis. This can be solved by adding a Where to the Graph Builder script, but not everybody knows JSL. And if we also want to use a Column Switcher (like in the User Community question), it requires a lot of JSL. See Example1.jmp.
The default behavior of the Graph Builder is also a problem when using Page. E.g. we have measurements for a lot of batches from different factories. I use the measurement as Y, Batch as X and Factory as Page and make it a Bar plot. The x-axis shows all batches, which means that most of each plot is empty space, while I would like it to only show the batches where there is data, i.e. the batches for that particular Factory. See Example2.jmp. I currently solve this by changing the Page to By, but then we loose a lot of nice properties that come with the Page setup.
A setting (the current can be default) like "Ignore/Skip x-axis values/categories with no data" that can be selected interactively in the graph builder. It could be under the Bar element settings if it doesn't apply/make sense for other graph elements.
Why is this idea important?
To avoid graphs with a lot of empty space which makes it impossible to see the trends we are actually looking for. To avoid having to do workarounds.
3 Comments
SarahGilyard
Thank you MTOF for posting this suggestion. Not sure if this is helpful to you, but this type of graph below is possible in graph builder.  I will pass along this suggestion for inclusion in the wishlist prioritization survey.
hogi
Level XIII
hi @MTOF , it's often the combination of values on the x axis and  X group or Page
please have a look at :folded_hands: X group: restrict the values on the axis to the respective group . It collected Kudos since 2 years and has the status "Investigating".
Any additional Kudo will increase the chance that the issue gets fixed in JMP19 ...
We just had a survey in our company : which limitation of JMP hurts the most
and :folded_hands: X group: restrict the values on the axis to the respective group was the clear "winner".
As I mentioned in Wish list - new Label: user experience , many cool new features can now be easily implemented in JMP - by a detour through Python or R.
But when a function is missing in GraphBuilder, it hurts.
hogi
Level XIII
For Page, JMP support suggests this workaouround:
the column which is used for page - use it in addition on the X AXIS - as an additional level (like in @SarahGilyard 's example).
With page, the user can specify the range for each subplot - to show just the non-blank regions.
... it takes a while - and it's dangerous if additional categories are added. But it works.
For X Group, there is no workaround.
