Get database connections from current JMP session
What inspired this wish list request? Getting connected to database from JMP  can take a while, especially with JMP 19, see:
JMP19 needs a lot longer for database queries - JMP User Community
So it would be a valuable information for an application, which connections are accessible quickly, as well as for user information.
I would need e.g. a function, that gives the "open" or established connections per session (e.g. where authentification is not neccessary anymore), see
Re: How to get database connections that have been used in current JMP session - JMP User Community
Why is this idea important?
it helps to make applications more effective and user experience better (less idle time)
2 Comments
Sarah-Sylvestre
Level V
Thank you for submitting this request!
guillaumebugnon
Level V
Hi,
Good idea.
It also will be good to debug the close database connection() function.
This one is not working since JMP 17.
Guillaume
