  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Get Unique Items
I repeated need to get a list of unique items from a column or list, and it would be nice to have a built-in JMP function and/or message that makes this easier.
My suggestion is two-fold:
  1. create a new message "<< get unique items" that can be passed to a data table column or String Col Box/String Col Edit Box that would return return a list of the unique values in that object
  2. create a new JSL function "Get Unique Items(list)" that would do the same thing for a list
Why is this idea important?
It is really mostly for some coding efficiency and readability of JSL code.  The current most efficient way to get the list of unique items from a list is to use
list={"a", "b", "a", "c", "a", "d"};
unique_items=(Associative Array(list) << get keys);
the alternative would be a bit simpler and more readable
unique_items = Get Unique Items(list);
Similarly, for getting a list of unique items from a data table
// common way to do this now
unique_items=Associative Array(<column reference> << get items) << get keys;
// proposed shorter and more readable way
unique_items = <column reference> << get unique items;
10 Comments
hogi
Level XIII
it will be:
col N unique (column)
with the additional possibility to get multiple counters via groupBy arguments:
Col N Categories - and all the others ...
super cool: the possibility to enhance the functionality via scoping
Transform Columns - as comfortable as Summary Statistics?
Sarah-Sylvestre
Level V
Yes, as @hogi stated, this function will be available in JMP 19.
hogi
Level XIII
And concerning
will it come as well?
BHarris
Level VII
I don't know if this is helpful, but here's how I do it:
  1. Select the columns you want to get the unique items from
  2. Rows -> Row Selection -> Select Duplicate Rows
  3. Rows -> Row Selection -> Invert Row Selection
  4. Copy
Now the system clipboard has a unique list of items in that column.  Pro-tip:  set keyboard shortcuts for items #2 and #3 and you'll have your list in just a couple seconds.
hogi
Level XIII
Nice trick!
Using associative arrays (as described in the original post) is another workaround.
Another option is to use Summarize(uniqueEntries=by(mycol)).
All of these methods work. Even better:
When you know it, remember it, tell your colleagues about it — you'll feel a sense of achievement!
It's so rewarding!
But after telling the 101st colleague the secret...
You wonder if something like this:
column << get Unique Items()
could make live easier.
... maybe as a wrapper for the Associative Array approach?
hogi
Level XIII
@Sarah-Sylvestre , could you please adjust the status of the wish?
Sorry, "my fault".
is super helpful - but not what @MathStatChem suggested in his wish.
Sarah-Sylvestre
Level V
hogi
Level XIII
Open( "$SAMPLE_DATA/Big Class Families.jmp" );
show(set unique(:name << get values());
Row() = 1;
Show( Set Unique( :sports ) );
MathStatChem
Level VII
That provides a partial solution.    I don't particularly prefer the name of the function, though.  "Set" is primarily used in JSL to set values or properties, so "Set Unique" implies something is being "set".  All the "Set" list functions (Set Unique, Set Union, Set Difference, Set Intersection) have that issue.  Would prefer the function name to be reverse order (i.e. Unique Set, Union Set, Difference Set, Intersection Set).
Set Unique( ) still requires some extra JSL to do what I wanted to do.  For table columns, you have either select the particular rows (using indexing or passing << get values to the column inside the function (Set Unique(:col[a::b]) or Set Unique(:col << get values)), and also for column boxes you have to still use a get message.
But it is a nice addition to the JSL function list.
hogi
Level XIII
Agree, when I found it in the scripting index, I  wanted to take a screenshot and share all the new Set functions with my colleagues - hm ...
One could build a custom function and call it via  get unique() ...
