JMP Wish List
Functional DOE: Adding Confidence intervals and Enabling Interactive HTML file export
(1) From 'Functional DOE Profiler' feacture in Functional Data Explorer in JMP Pro, I would like to see
  (1-1) Confidence Intervals   and
  (1-2) Interactive HTML file export from the profiler
(2) From 'Model Comparison' in JMP Pro,
   (2-1) 'Model Averaging' (Ensemble) result showed a fixed RSquare (1.00) and RASE (0.00). I think it's a bug.
   (2-2) Shelf made 'Ensemble model' that is formulated from other models (Least Squares, Partial Least Squares, SVEM Lasso, XGBoost, Neural Turned with different weight) also showed a fixed RSquare (1.00) and RASE (0.00) value in Model Comparison results.
Why is this idea important?
3 Comments
Steve_Kim
(1-1) I have noticed that the confidence intervals of the Functional DOE Profiler was already listed.
https://community.jmp.com/t5/JMP-Wish-List/Confidence-Intervals-for-functional-DoE/idi-p/413151
(1-2) The functional DOE Profiler has been saved in interactive HTML format using JMP Pro 18 (Graph > Profiler).
Hello @Steve_Kim Thanks for your interest in contributing ideas for future improvement of our FDE platform!
If you have not done so already, can you kindly submit your Request (2) to support@jmp.com so we can further investigate/ assist you?
In your email solicitation, please provide the following information if possible:
1. Your JMP Pro version and your OS/ version.
2. An example data table in JMP with saved data table script that reproduces your Model Comparison output.  If you can't provide that, then please provide a description or illustration of your modeling specifications for each model being compared, and clear screenshot(s) of your Model Comparison output.
cheers,
-@PatrickGiuliano (JMP Technical Support)
SarahGilyard
Hi Steve_Kim. An update on your FDOE confidence intervals request ...  we are currently researching the feasibility. Due to the complexity of the models used, offering an accurate confidence interval with the correct coverage is tricky. We have had multiple requests for this functionality, so we are studying it.
Regarding the possible model comparison bugs, if you haven't already done so, could you please submit your request to support@jmp.com so our tech support could further assist you.
Thanks.
