  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Function to remove repeated characters in a string
Hi.  I'm interested in a function that could be used to remove repeated characters from a string.
What inspired this wish list request?  If I have a string that contains the same repeated character and sometimes I want to remove all but one instance of that character.  For instance, I have a string like "input1;;;;input2;;;input3", and I want to convert it to "input1;input2;input3".  I assumed I could just use SubstituteInto(str, ";;", ";") and it would recursively remove all repeated ";", but did not.  Instead it just would replace only the first 2 semicolons with a single semicolon, then stop.
str = "input1;;;input2;;;input3";
SubstituteInto(str, ";;", ";");
Show(str);   //returns "input1;;input2;;;input3"
Note that the first set of semicolons was reduced from 3 to only 2, and the second set was not affected at all.  My current workaround is to embed this in a while loop:
curlen = Length(str) + 1;
While(Length(str) < curlen,
);   //returns "input1;input2;input3"
What is the improvement you would like to see? I'd like to see a modification to the Substitute(), SubstituteInto(), and Munger() functions to include a "<< RECURSE" message that just makes it perform the same operation as the code above:
Substitute(x, patternString1, replacementString1, ..., < <<IGNORECASE >, < <<RECURSE >);
SubstituteInto(x, patternString1, replacementString1, ..., < <<IGNORECASE >, < <<RECURSE >);
Munger(s, startpos, findstringOrNChars, <replacestring, < <<RECURSE > >);
Alternatively, rather that change established functions, perhaps a new function could be created called "Trim Multiple()"
Trim Multiple(s, patternString);
where s is a string and patternString is one or more characters.  The code will search through s for any instances of patternString that are repeated consecutively.  Where it finds one, it replaces it with just one instance of patternString and continues searching s for more instances of patternString.
Why is this idea important? This would reduce the complexity of users' codes.  It would also be a way to help to highlight to users that the Substitute()/SubstituteInto()/Munger() functions are -not- inherently recursive, and in doing so this would help prevent bugs.
3 Comments
hogi
Level XIII
While waiting for Trim Multiple(), you can use a combination of words() and concat items():
Show(concat items(Words(str, ";"), ";"))
nikles
Level VI
@hogi thanks for the idea.  This is much more compact than my while loop.
scott_allen
We will keep an eye on this to see if there are additional use cases that would benefit from a new function. In the meantime, it appears that @hogi's solution is sufficient.
