  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
For loop: set first / last executed entry
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
During script debugging, I often want to look into a for loop and execute the code step by step for one of the items.
Most interesting: start the loop with the last value [e.g. after a failure]
All parameters are already set by the last run, just the looping parameter is missing. This is why most of my for loops look like this:
For Each( {mydt}, openTables,
  // mydt = openTables[13]
the disabled code can be executed to set the looping parameter for debugging.
Please add a command to the right click context menu:
[edit] plan B: Just copy the behavior of the for() loop:
make the looping parameter accessible from outside the loop.
-> if the code stops, the looping parameter is the last one in the cycle.
-> great for debugging
Why is this idea important?
It's not important, but every *) JSL coder will love you.
*) maybe there was a reason to change the behavior.
So: maybe not every  JSL coder is happy to see the old (deprecated?) behavior.
3 Comments
hogi
Level XIII
half a year and just 2 Kudos.
@Sarah-Sylvestre , could you please archive this wish : )
hogi
Level XIII
@Sarah-Sylvestre
low prio -> can be closed and reactivated once the important ones are finished.
hogi
Level XIII
Ah, now I got it!
It's a disadvantage of the For each loop!
Python:
fruits = ["apple", "banana", "cherry"]
for x in fruits:
  print(x)
print("__")
print(x)
-> works
JSL # 1: for() loop:
Names default to here(1);
for(i=1,i<3,i++, 1);
Print(i);
-> works
JSL #2: for each() loop
for each({j}, 1::10,Print(j));
Print(j);
-> fails : j is not defined outside of the for each() loop
-> makes it difficult to debug the code
