%3CLINGO-SUB%20id%3D%22lingo-sub-393512%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAjuste%20de%20l%C3%ADnea%20fija%20en%20el%20editor%20JSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-393512%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EActualmente%2C%20cuando%20haces%20Ctrl-M%20para%20%22formatear%20el%20script%22%2C%20la%20forma%20en%20que%20se%20ajusta%20el%20texto%20depende%20del%20tama%C3%B1o%20de%20la%20ventana%20del%20editor.%20Esto%20es%20realmente%20terrible%20si%20est%C3%A1%20utilizando%20algo%20como%20git%20para%20administrar%20sus%20scripts%2C%20ya%20que%20puede%20haber%20muchos%20cambios%20en%20su%20script%20que%20en%20realidad%20son%20simples%20cambios%20de%20ajuste%20de%20l%C3%ADnea.%3C%2FP%3E%3CP%3EMe%20gustar%C3%ADa%20que%20el%20editor%20admita%20algo%20as%C3%AD%20como%20un%20valor%20de%20ajuste%20fijo%2C%20de%20modo%20que%20el%20ajuste%20del%20texto%20cuando%20%22formatea%20el%20script%22%20NO%20dependa%20del%20tama%C3%B1o%20de%20la%20ventana%20del%20editor%20de%20script.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-393512%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ELa%20personalizaci%C3%B3n%20en%20masa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-778847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ajuste%20de%20l%C3%ADnea%20fija%20en%20el%20editor%20JSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-778847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHm%2C%20me%20gusta%20la%20posibilidad%20de%20ajustar%20el%20ajuste%20de%20l%C3%ADnea%20a%20trav%C3%A9s%20del%20tama%C3%B1o%20de%20la%20ventana.%3CBR%20%2F%3E%3CBR%20%2F%3E%20Entiendo%20el%20problema%20con%20GIT.%20Por%20lo%20tanto%2C%20si%20se%20introduce%20un%20valor%20de%20ajuste%20fijo%2C%20proporcione%20una%20opci%C3%B3n%20que%20permita%20al%20usuario%20elegir%20su%20modo%20preferido.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Fixed Line Wrapping in JSL Editor
Currently when you do a Ctrl-M to 'reformat the script', how the text wraps depends on the size of the editor window.  This is really awful if you are using something like git to manage your scripts, as there can be many changes to your script that are really just simple line wrapping changes.
I would like to see the editor support something like a fixed wrapping value, such that the text wrapping when you "reformat script" does NOT depend on the size of the script editor window.
1 Comment
hogi
Level XIII
Hm, I like the possibility to tune the line wrapping via the window size.
I understand the issue with GIT. So, if a fixed wrapping value gets introduced, please provide an option which allows a a user to choose his preferred mode.
