Fast Fourier transform
Signal processing is important as a preprocessing process for analyzing manufacturing data such as equipment processing waveforms. "wavelet transform" will be added to JMPPro17, but at the same time I would like to add a simple signal processing "Fast Fourier transform". Various signal processing is necessary for preprocessing of time series analysis including waveforms. This signal processing can be converted into structured data, expanding the range of data that can be analyzed by JMP. In the manufacturing industry, it is very important and needs are also large. I would like to do more strongly than that.
