Export tool supporting Word and PPT
Have more than 30scripts in each file - this export option will help exporting each plot into a word or ppt slide avoiding manually copy pasting them over multiple JMP files.
Why is this idea important?
Have more than 30scripts in each file - this export option will help exporting each plot into a word or ppt slide avoiding manually copy pasting them over multiple JMP files. This will help save time.
2 Comments
Sarah-Sylvestre
Level V
Status changed to: Needs Info
Hi, could you provide a bit more information about this request? For example, are you trying to get multiple JMP reports all into the same PowerPoint file? If so, a current workaround is to save the reports to a journal and then export the journal to PowerPoint.
ExogenousBandit
Level II
Hi,
I have multiple scripts in a single JMP file (about 30 different plots) - I am looking for a plugin so that I can save each plot in an individual slide or even in a document one plot per page inside the document. Hope this information helps.
BTW - Are there any steps on how to save the reports to a Journal?
Thanks,
Vinay
