We want to hear your ideas for improving JMP software.
  1. Search: Please search for an existing idea first before submitting a new idea.
  2. Submit: Post your new idea using the Suggest an Idea button. Please submit one actionable idea per post rather than a single post with multiple ideas.
  3. Kudo & Comment Kudo ideas you like, and comment to add to an idea.
  4. Subscribe: Follow the status of ideas you like. Refer to status definitions to understand where an idea is in its lifecycle. (You are automatically subscribed to ideas you've submitted or commented on.)
We consider several factors when looking for what ideas to add to JMP. This includes what will have the greatest benefit to our customers based on scope, needs and current resources. Product ideas help us decide what features to work on next. Additionally, we often look to ideas for inspiration on how to add value to developments already in our pipeline or enhancements to new or existing features.
Expire date notice : Revert from JMP18 style (pop-up) to JMP17 style (on the title screen)
このウィッシュリストリクエストのきっかけは何ですか?改善が必要な現在の問題、または現時点では簡単または不可能である解決すべき問題について、ユースケースの例を示して説明してください。
Issue about expire date notice:
With JMP18, the specifications have changed so that a pop-up window appears after launch starting 30 days before the license expires.
In this case, it is expected that many users will contact the administrator before the next annual renewal.
This could cause confusion in management work.
改善してほしいことは何ですか?JMPを改善するためのアイデアを説明してください。 希望する変更を説明するために、モックアップ、ワイヤーフレーム、スクリーンショット、スクリプト、その他のドキュメント、または他のソフトウェアの例を含めてください。
Stop pop-uping expire date notice.
For example, revert to the specifications before JMP17, where the expire date is displayed only on the title screen with red text.
この考え方がなぜ重要なのでしょうか?アイデアが実装された場合は、その価値をあなたや他のユーザーに説明してください (例: 使いやすさ、必須など)。
"Reverting from JMP18 style (pop-up) to JMP17 style (on the title screen)" can be suppress increasing of management work.
Off course, you can avoid pop-up notice by paying license fee more than 30 days before expire date. But, it is very difficult for many company. You can avoid expected new management confusions without early payment by this idea.
1 Comment
jthi
