Our company is now using automated scripts in JMP connecting to our Laboratory management system, LIMS, to pull data for SQC reports. These need to be reviewed for 'bad data' prior to sending to customers. Samples undergo multiple tests which need to be arranged in columns - 1 row per sample. Most of the 'bad data' relates to a single test (maybe a typo or a measurement special cause) so we don't want to exclude the whole suite of testing just to remove that single point.
JMP's row structure to data currently means the only way this is possible is to exclude values in column properties or delete the value from the cell.
