Error in JMP?
Please check the report generated by "Fit Proportional Hazards" when all observations in one group are censored.
Why is this idea important?
Removal of a possible (minor) error in JMP.
2 Comments
SamGardner
Level VII
@winfriedkoch0 thank you for the note on this issue.  For issues that you think are bugs or errors in JMP, please send this our technical support group (support@jmp.com).  It would be helpful if you could also provide more detail on the problem, including a more complete description of the data (or even better and example data set) and the problem you are seeing with the results generated by JMP.
winfriedkoch0
Level IV
Sam, I tried what you recommended but I could not reproduce the assumed error.
Please consider the issue as solved.
Winfried
