Design Explorer Enhancements with Blocking and Hard-to-Change Factors
Design Explorer is a really good new feature in JMP 17 for comparing multiple candidate designs in Custom Design. However, you can't utilize it if there are Fixed Blocks, Random Blocks, or Hard-to-Change factors in the experiment. So this is a bit limiting.
I'd like to see new versions let you utilize Design Explorer for these scenarios.
In the current version, it is slightly misleading because you can check the box for Random Blocks initially, but the Design Explorer menu will then drop it in subsequent evaluations. I did not notice this until after a run sheet was generated. The initial setup screenshot is shown below.
5 Comments
Hi @jszarka, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
mia_stephens
Hi @jszarka, handling random blocks and hard-to-change factors in Design Explorer is being considered, potentially for the next release. According to development, accommodating fixed blocks is more difficult and requires additional research.
jszarka
Level V
Thanks, @mia_stephens!
