%3CLINGO-SUB%20id%3D%22lingo-sub-342681%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EDecouple%20Scatterplot%20Matrix%20Axes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-342681%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CU%3EIssue%3C%2FU%3E%3A%20Sometimes%20categoric%20factor%20settings%20have%20long%20names%20and%20it%20makes%20sense%20to%20change%20the%20alignment%20to%20either%20vertical%20or%20horizontal%20in%20the%20axis%20settings%20so%20you%20can%20see%20the%20whole%20name.%20However%2C%20when%20you%20do%20this%20on%20the%20scatterplot%20matrix%20it%20changes%20both%20sides%20of%20the%20factor%20settings%20on%20the%20x%20and%20y%20axes.%20So%20I%20can%20get%20it%20to%20look%20right%20on%20one%20axis%20but%20not%20the%20other.%3C%2FP%3E%3CP%3E%3CU%3ESuggestion%3A%3C%2FU%3E%20Decouple%20the%20factor%20axes%20so%20I%20can%20make%20a%20change%20to%20one%20axis%20while%20not%20affecting%20the%20other.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-342681%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistics%20and%20Analytics%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Decouple%20Scatterplot%20Matrix%20Axes%20-%20Status%20changed%20to%3A%20Archived%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWe%20are%20archiving%20this%20request.%20If%20this%20is%20still%20important%20please%20comment%20with%20additional%20details%20and%20we%20will%20reopen.%20Thank%20you!%3C%2FLINGO-BODY%3E
Decouple Scatterplot Matrix Axes
Issue: Sometimes categoric factor settings have long names and it makes sense to change the alignment to either vertical or horizontal in the axis settings so you can see the whole name. However, when you do this on the scatterplot matrix it changes both sides of the factor settings on the x and y axes. So I can get it to look right on one axis but not the other.
Suggestion: Decouple the factor axes so I can make a change to one axis while not affecting the other.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
