%3CLINGO-SUB%20id%3D%22lingo-sub-706324%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ENombre%20d%C3%A9cimal%20par%20d%C3%A9faut%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-706324%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3EL'affichage%20de%20tableaux%20avec%20des%20nombres%20d%C3%A9cimaux%20peut%20pr%C3%AAter%20%C3%A0%20confusion%20lorsqu'il%20y%20a%20un%20grand%20nombre%20de%20chiffres.%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuelle%20est%20l%E2%80%99am%C3%A9lioration%20que%20vous%20souhaiteriez%20voir%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3EPossibilit%C3%A9%20de%20param%C3%A9trer%20le%20nombre%20de%20d%C3%A9cimales%20par%20d%C3%A9faut%20affich%C3%A9es%20dans%20le%20tableau%20(par%20exemple%20limiter%20la%20valeur%20par%20d%C3%A9faut%20%C3%A0%202)%20dans%20les%20pr%C3%A9f%C3%A9rences.%20Cela%20nous%20%C3%A9vitera%20de%20le%20faire%20pour%20chaque%20table%20ou%20colonne%20souhait%C3%A9e%20(m%C3%AAme%20si%20l'option%20%C2%AB%20Standardiser%20les%20attributs%20%C2%BB%20aide)%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%20%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3EAide%20%C3%A0%20la%20lisibilit%C3%A9%20dans%20les%20tableaux%20JMP%26nbsp%3B%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-706324%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcc%C3%A8s%20aux%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EExploration%20et%20visualisation%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Decimal number by default
Displaying tables with decimal numbers can be confusing when there is a large number of digits.
Possibility of setting the default number of decimal places displayed in the table (for example, limit the default to 2) in the preferences. It will avoid us to do it for each table or desired columns (even if the « Standardize Attributes » helps)
Why is this idea important?
Help readability in JMP tables;
