Customize pValue to set correlation criteria
Hi,
  In JMP screening functions such as Response screening, add an input field of threshold pValue in the GUI to allow customers to set their own thresholds for finding strong correlation, instead of JMP's own default 0.05 or 0.01 value.  These values seem to be too loose to find strong correlation between response and factors.
Thanks,
Shen
5 Comments
mia_stephens
Status changed to: New
Thank you for this suggestion @Bluesky. It has been submitted for consideration.
SamGardner
Level VII
SamGardner
Level VII
Status changed to: Needs Info
@Bluesky can you provide some additional information for us?  In response screening, we currently display on the FDR PValue plot the PValue = 0.05 and FDR PValue=0.05 lines.
We also provide the ability using the red triangle menu to "Select Where", and specify a criteria to select comparison results, where you can pick your own PValue threshold to use.
Does this meet your needs, or is there something else we can do to meet your needs?
SamGardner
Level VII
@Bluesky checking back with you.  Does the current options described above meet your needs?
SamGardner
Level VII
Status changed to: Not Planned For Now
We have not received a response to the request for more information, so we are closing this request.  If you have additional information to share, we can re-open this and investigate further.
