What inspired this wish list request? Control Chart Builder (CCB) is the key platform moving forward, particularly with the legacy charts being retired. CCB offers lots of dynamic capabilities, but in my opinion can be a little clunky and the default views can be improved.
What is the improvement you would like to see? Below I list several items that I've shared with other JMP users from several companies that agree that would be nice "quality of life" adds to the CCB platform.
Why is this idea important? Current users still using the legacy platform are disappointed with it being retired for a reason. CCB may offer new features, but some of their traditional views and user experiences in the legacy platform leave them wanting to stay there. By integrating the best of both worlds into CCB, users moving forward can be very satisfied.
- Improved scaling of the y-axes. I find in CCB they are very "tight" as the control limits can be very close to the min/max established. Fitting the same chart in the legacy platform typically offers better orientation (as does Graph Builder). Utilizing the same logic for the limits can be an improvement.
- Show Limit Labels to match the legacy platform. Currently they are inline on the right-hand side, which will change the orientation of the graph. If they are shown on the outside of the graph like the legacy platform, the graph will be unchanged and preserved.
- Shorten the labels of the y-axes for the different charts. I noticed improved displays in JMP 18, and this is worst with crowding in 3-way charts. The easiest fix in my mind is to create an option for 'abbreviated labels' that would use 'Mean/Avg/Xbar', 'MR', 'R', 'S/StdDev' and also potentially remove the units for brevity and the fact that it matches the common language (e.g., Xbar-R charts). You could potentially update the title as well to shorten it too.
- Change the default Graph Spacing Color to match the overall background color. The dark gray is not the best. My personal option is to use Graph Spacing = 15, Graph Spacing Transparency = 0, and Graph Borders = On to help separate the sections of the graph. This personal option also matches what is used in the JMP 18 Sample Preset "IMR Chart with Tests."
- Enhance the By variable broadcasting. When invoked, separate control panels still need to be manipulated individually on the control panels in the left pane.
I think these are small adds that can make a difference - and possibly others in the community have great ideas as well to weigh in on!
