  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Native support for '.FCS' files
An inability to open .FCS file extensions natively in JMP and a recommendation to submit an idea.
It would be great if .fcs files could be recognized and opened directly into JMP as JMP already has a ton of built in capability that makes processing data of this format very easy. It seems that files currently need to be converted into a .txt or .csv format first to be opened. Since .FCS files mainly contain scatterplot data I think there could be some easy translation of JMP functionality into processing these files.
Why is this idea important?  Because of the demographic that typically uses software like JMP there are likely many other flow cytometer operators in my situation who don't want to use a completely different software to open and analyze these data. Would be awesome to use a data analysis platform we are already familiar with and have access to.
3 Comments
Sarah-Sylvestre
Level V
Thank you for taking the time to submit your request! We have shared this feedback with the development team. I will let you know if there are any changes to the status.
jlam
Level I
Apparently, FCS 2.0 and 3.0 are already supported in JMP. Why not support FCS 3.1?
Sarah-Sylvestre
Level V
Hi, thank you for your comment! You’re absolutely right—FCS 2.0 and 3.0 are already supported in JMP. While there aren’t current plans to support FCS 3.1 natively, there’s been some early exploration into whether a marketplace add-in could help bridge that gap. I can’t promise anything in terms of implementation or timing, but please know that we really appreciate your feedback and are listening.
