Control Box Plot design in preferences
Dear all,
we use Box Plots a lot, and the new features in JMP 16 (notched ...) are great,
but it would be quite helpful to be able to control these features already in preference settings.
So I would vote for including features like
Box Style( "Solid" ), Notched( 1 ), Fences( 1 ), Name( "5 Number Summary" )(1)
in preferences to not need to specify them in each plot again.
See script and screenshot for illustration.
Thanks,
Names Default To Here( 1 );
// styled Box Plot with notch and colos
dlg = Column Dialog(
	xCols = Col List( "X, Factors", Min Col( 1 ), Max Col( 1 ), Modeling Type( "Categorical" ) ),
	yCols = Col List( "Y, Response", Min Col( 1 ), Max Col( 1 ), Modeling Type( "Continuous" ) )
gb = Graph Builder(
	Show Control Panel( 0 ),
	Variables( X( dlg["xCols"][1] ), Y( dlg["yCols"][1] ), Color( dlg["xCols"][1] ) ),
	Elements( Box Plot( X, Y, Legend( 3 ), Box Style( "Solid" ), Notched( 1 ), Fences( 1 ), Name( "5 Number Summary" )(1) ) )
6 Comments
DZEMKE
Level I
Very good idea. I would like to see it go into the preferences.
AlexM
Level I
Good proposal , voted
Sarah-Sylvestre
Level V
Hi @Georg, thank you for your suggestion! We have captured your request and will take it under consideration.
ivo
Level II
good idea. would like to see it in preferences
Hello @Georg , did you try to use the presets. You can configure your box plot design and save this pre-configuration as a preset and use the preset for always the same  display. If that works can we assign your request as delivered?
Georg
Level VII
Hello @Valerie_Nedbal , yes, I tried it out, I can use presets for this. Thanks and best regards, Georg
