  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Confidnece interval around difference in survival
The problem statement is I want to be able to compare 2 populations' survival and give a confidence interval around the point estimate. JMP can plot a simultaneous or pairwise confidence interval around any given population, but cannot give a confidence interval around the difference. Therefore, I suggest to everyone in my company to use R or python to do survival analysis, because the point of comparing survival is to quantify the difference, and the uncertainty in the difference.
RMST is one way to compare survival across 2 populations and derive confidence intervals.
https://cran.r-project.org/web/packages/survRM2/vignettes/survRM2-vignette3-2.html
I suggest JMP impelement RMST.
3 Comments
Mark_Zwald
The Compare Groups perspective of the Life Distribution platform may be able to give you the desired result to compare survivability across groups.  Try running this script which compares two groups of life distributions and using the Estimate Probability option, compares survival rates at specific intervals (ex. 100, 200, 500, and 1000 time cycles).
Open( "$SAMPLE_DATA/Reliability/Blenders.jmp" );
Life Distribution(
	Perspective( Compare Groups ),
	Y( :Time Cycles ),
	Grouping( :Group ),
	Censor( :Censor ),
	Censor Code( 1 ),
	Confidence Interval Method( Wald ),
	Select Distribution( Distribution, Weibull ),
	Select Scale( Weibull ),
	Tabbed Report( 0 ),
	Estimate Probability( 1 ),
	Estimate Probability( Compute( [1000, 500, 200, 100] ) ),
	SendToReport(
		Dispatch(
			{"Life Distribution - Compare Groups", "Statistics"},
			"Group Homogeneity Tests",
			OutlineBox,
			{Close( 0 )}
		Dispatch(
			{"Life Distribution - Compare Groups", "Individual Group"},
			TabListBox,
			{Set Selected( 2 )}
		Dispatch(
			List Box( 2 ),
			{Set Summary Behavior( "Collapse" )}
		Dispatch(
			List Box( 76 ),
bayesfactor1
Level II
Thank you for your script. That inputs confidence intervals around each population independently. I'm asking for a confidence interval around the difference in 2 populations, which is not the same thing and commonly misused. For examples, please see Fig 1c and Fig 3c in this paper: https://doi.org/10.1038/nmeth.2974
bayesfactor1
Level II
I have a working implementation in python, here: https://github.com/bayesfactor/lifelines/blob/f447b266549ee666eef37df69469473ba5073076/lifelines/sta...
I hope this helps you to implement in JMP. Can you please provide an update on where this feature is in your development queue? Thanks
