Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
I usually use Cividis (custom, as I have reversed colors) for Continuous and Sequential, Universal Bad to Good for bad to good and Universal for Categorical
In JMP 17, in the Graph Builder, if you click the red triangle and select "Color Setting", there is a link to the color theme settings
From there, if you choose the Continuous or Categorical color them, it takes you to the color settings. From there you can choose the color theme, and then in the color vision setting choose the appropriate color vision "filter", which will adjust the color theme for that type of color vision.
