JMP Wish List
Color of lines based on row colors
I usually use Summary table to give my rows specific markers and colors to code for e.g. product groups in stability data etc.
When making graphs using fit Y by X the data points have the right color and marker. When then grouping by batch and adding flexible lines the software typically uses the correct color from the row.
But when then adding and using a local data filter it mixes up the colors so that line and row do not fit any more.
I would like an option (button etc) to make the software use the row color as line color.
Why is this idea important?
Using same color for data points and lines greatly increases transparency in large data sets.
Change line color manually back to row color costs too high amount of time.
5 Comments
Sylvie
it will allow us to save time
MultipleFrog969
It takes so much time and nerve to rearrange the colors correctly! It would be great to have that option!
Sarah-Sylvestre
Hello, thank you for sharing this request and to others for commenting their support. We are reviewing this issue. I will let you know if there are any updates.
Sarah-Sylvestre
Status changed to: Yes, Stay Tuned!
Hello! This was a bug and has been fixed, so now the line colors should remain when using local data filter in JMP 19.
Sarah-Sylvestre
Status changed to: Delivered
