Color map on correlations in the right order and with labels
According to the manual, the variable clustering colormap should be as described here:
Color Map on Correlations
"The variables are arranged in the order in which they are listed in the Cluster Members table."
But unfortunately, the sort order in the map is first, by cluster, and then by variable name. The cluster members table on the other hand, is sorted by Cluster and then by RSquare with Own Cluster. This has been the case, at least since JMP 16, and it has caused some confusion, especially since axis labels are not shown on the plot, and there is no easy way to add them in the platform.
I would like that:
1. The order in the color map is as described, i.e. by cluster and by RSquare with own cluster as in the cluster members table.
2. An option to add Axis labels to the color map so that the color map can be used in presentations. The axis labels should show both the cluster number and the variable name.
It is important because currently, the plot is being misinterpreted and it is not possible to use it in a presentation without axis labels.
1 Comment
thomasz
Level IV
Just realized that the cluster members table is sorted in (almost) RSquare with own cluster, but not entirely. Difficult to determine what the exact sort order is.
The color map is sorted, as stated in the wish post.
