  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Changing the Orientation of Axis Labels Inside the Axis
A co-worker was struggling today to make chart with multiple reference lines. It's the kind of chart where the labels need to be vertical for readability, but I found when helping her that if I changed the Label Position to anything other than Outside, the orientation setting would not stick. If I select Vertical, it only works on the outside labels. So you get a mix of horizontal and vertical labels. In this case, we want them all to be vertical, whether it's inside or outside the axis.
1 Comment
Sarah-Sylvestre
Level V
Hi, thank you for bringing this to our attention! I will let you know if there are any status changes to this wish.
