I use the Chinese version of JMP and basically run it in scripts. I often use Chinese as variable names when writing scripts (not a good habit). Need in the new version of JMP "script editor" implementation: after the script runs, the Chinese variable has been assigned.When the cursor points to the Chinese variable, the result of the variable can be displayed. This function can normally display the content of Chinese variables in JMP 15 and JMP14.But not since JMP 16. Thanks!
