Can the listbox have a select all command
Can the listbox have a select all command, at the moment you can only select one by one. Use lb<<set selected(1)
listbox has a command to select all elements at once.
Why is this idea important?
Many commands have this, but listbox does not; for example, checkbox
6 Comments
SamGardner
Level VII
Thanks for the idea @lehaofeng. We will look into this.
As a workaround, you can use a short script to do this
Names Default To Here( 1 );
New Window( "List Box", Outline Box( "List Box", lb = List Box( {"a", "b", "c"} ) ) );
For( i = 1, i <= N Items( lb << get items ), i++,
	lb << set selected( i )
and you could make a function to do this
listbox_select_all = Function( {listboxref},
	{i},
	Try(
		If( listboxref << class name() == "ListBoxBox",
			For( i = 1, i <= N Items( listboxref << get items ), i++,
				listboxref << set selected( i )
listbox_select_all(lb);
SamGardner
Level VII
lehaofeng
Level V
Thanks, tried it with the method you provided and it is very slow. Because there are scripts in the list box that set the row state of the table, and the selected elements, corresponding to the rows in the table, are hidden and excluded, so when I have 4000 elements in my listbox, it is very slow.
SamGardner
Level VII
Status changed to: Under Consideration
This looks like something that we can do in a future release.  We will follow up when we decide when to add this capability.
This will be available in JMP 19.
Status changed to: Delivered
