  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Calculation of Tolerance Intervals for Non-Normally Distributed Data
Like in other statistical software it would be nice to be able to calculate tolerance intervals for the following non-normal distributions:
  1. Lognormal
  2. Gamma
  3. Exponential
  4. Smallest extreme value
  5. Largest extreme value
  6. Logistic
  7. Loglogistic
  8. Weibull
I know there are some workarounds and normalizing via transformation ist always a possibility, but having just to press one button would be perfect.
Best regards,
Christian
6 Comments
Sarah-Sylvestre
Level V
Hi @christianguhr, thank you for your suggestion! We have captured your request and will take it under consideration.
Stoic
Level I
Piling onto this request.  New JMP user here, and I'm surprised that this feature is missing.
Thanks for chiming in here @Stoic. As of JMP 18.x, we do have a way of generating these but not in the "traditional sense," i.e. using the Tolerance Intervals red triangle menu option under the Distribution platform (similar how you might report/ generate these in a competitors' statistical package).  I am planning to write a JMPer Cable Article that walks through that process and will try and circulate it here once I have it done.
Stoic
Level I
Thanks, will stay tuned.  We're med dev and will have to validate the method in order to use it, so hopefully a test data set and expected results will be available with this.
ChrisGaltress
Level I
Hi Patrick,
Any update on JMPer Article?  Agree with others that this would be a welcome addition to JMP.  I'm currently working on a project that requires calculating tolerance intervals from numerous (100s) of simulated non-normal sample sets.  I'm working mostly w/ Weibull, Lognormal, and SHASH distributions and would like to be able to calc & export the lower bounds at 90% coverage & 95% confidence for these sample sets into table format to estimate the predicted failure rate of being below the lower bound.
Hello @ChrisGaltress, No update unfortunately, I haven't been able to get to this.  Let's try a different approach.  Can you please send us an email to [email protected] and address it to me directly? "Hi Patrick..." Please reference this community post and give the subject line a meaningful header "Calculation of Tolerance Intervals for Non-Normally Distributed Data."  I can work with you directly to demonstrate the 'alternate' approach that I am thinking for your case, and to identify its limitations (off hand, we don't support SHASH in Life Distribution which is where I think you would need to go here).
