  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Bring back the crossvalidation option in Partition platform menu
Since JMP 16, either the normal and pro versions, the menu option for cross-validation is gone! To use cross-validation with decision trees, you need to use the Model Screening platform (new in JMP Pro only), and you can't modify any tree building option in there. This is more a downgrade than an upgrade! It was very convenient to have cross-validation along with all other options in a self-contained analysis platform.... Please bring it back!
6 Comments
mia_stephens
Status changed to: New
I believe you're referring to k-fold crossvalidation in Partition? You can turn this on in the preferences for Partition.
Correction: It was turned off as a default option in Partition because k-fold within the partition platform tends to result in overfitting - it doesn't stop soon enough. Within Model Screening k-fold is done external to the partition platform, so it works better there.
mia_stephens
Status changed to: Already Offered
VincentBechard
Level III
Hi,
Yes I turned to option On. But there is a balloon tip saying "Deprecated feature", so I know it could disappear in the next releases. And, more important : it does not display the option in the menu of the platform, it's just a popup before the platform opens. In other words, it is not what I used to have before!
Is there a way or an addin that could bring back the menu?
Regards,
Vincent
mia_stephens
mia_stephens
Hi Vincent,
Here's a little more information. The menu item was removed because k-fold in partition did not work as you might expect, and tended to result in models that did not generalize well to new data. As a result, these models aren't as useful. In studies, we found that random holdout in Partition (from the launch dialog) performed better on holdout data than k-fold.
That said, thank you for submitting this wish for consideration. I've changed the status back to Open for Voting.
Warm regards,
Mia
VincentBechard
Level III
Hi,
I think "something" should be there for k-fold validation. Users without a Pro license lost an important feature! But you are true, the good old Holdout approach still works well, and works very fast on large datasets.
Thanks,
Vincent
