Be able to easily convert the cross hair tool lines into an axis reference line
What inspired this wish list request? I use the cross hair tool a lot and especially like the ability to hold down control to broadcast the lines across multiple panels in a chart.  This allows me to easily see if shifts or trend are happening across multiple functions at the same time and/or with the same magnitude.  However, if I have to scroll down to see more process'
 and the original process of interest disappears it becomes cumbersome to use as I have to write down the value I'm interested in and then manually add in an axis reference line.
What is the improvement you would like to see? I'd like to have the ability to right click when you are on the cross hair and have the option of turning the Y value, X value or both into axis reference lines automatically.
  • An additional request of the cross hair
    • the ability to turn off the "magnifying glass" but keep the values shown.  Right now you can get rid of the glass by holding alt but then the values disappear as well
    • Have the ability for the Y axis values to show all Y axis data, right now it just shows the first data that was added to the Y axis
    • For the X axis, have the ability to show the value of the column it is sorted by along with the base data.  So for example, if I have batch number as the x axis and then sort it by ship date, have the cross hair show the batch value and the ship date.
Why is this idea important? this will allow interacting with your data vis the crosshairs be more efficient and fluid.
2 Comments
Thank you for submitting this request!
SkyHigh25
Level I
I love the idea of having h and v ref created by crosshairs. I would like to add to this request. Please add an option to make the cross hair default to broadcast across all panels. See this Bokeh example for reference.
