Avoid using SendToReport and Dispatch when saving scripts
Often saved scripts include Send to Report and Dispatch functions, and users (both new and experienced) copy/paste these into other scripts without replacing that code with references directly to each object.  When an unsuspecting user tries to modify this auto-generated code and posts a question on the JMP community they are chastised for using the Send to Report and Dispatch functions.  It would be helpful if new platforms didn't use this syntax and if eventually it was replaced in existing platforms.
1 Comment
