  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Augment Design Includes Specifying Number of Whole Plots
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case. If the design you are augmenting is in a split-plot structure, you can specify the total number of runs, but not the number of whole plots. Suppose an initial design had 5 whole plots with 25 runs, then if I increase the design size to 40 runs, Augment Design automatically assigns 3 new whole plots as it must be 5 runs per whole plot. With sequential experimentation, that could easily change and if 3 runs are desired per whole plots, we may want those 15 additional runs to span 5 whole plots instead of 3 to improve the design evaluation criteria.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see. In Custom Design, a split-plot experiment lets you specify the "Number of Whole Plots" as well as the "Number of Runs." Augment Design only lets you have the latter, but including the former should be simple and can easily mirror what is already familiar to users in Custom Design.
In my specific example, it may look like this:
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).The Custom Design platform offers great flexibility for experimenters to design the right experiments for their problems. Since Augment Design uses similar methodology, offering that flexibility is another value-added improvement.
3 Comments
mia_stephens
Thank you for this suggestion @jszarka! We've got some other requests related to Augment Design, and will get this in the queue.
Audrey_Shull
Sarah-Sylvestre
Level V
Status changed to: Delivered
