Allow us to perform more actions when right clicking on column name on columns panel
Working with data tables with hundreds or thousands of columns.
Browsing columns pane is fast and it can be filtered down quickly and you cannot do that with column headers (or with the table). I would like to be able to perform more actions we can perform from columns header from columns pane. Especially copying/pasting/inserting but I wouldn't mind if I had all the possible options under some new drop-down menu.
One possible mock-up of the idea (there are some options which shouldn't be included and some are duplicated)
Why is this idea important?
Makes it easier to work with very wide tables.
3 Comments
hogi
Level XII
Thumbs up!
nowadays, one has to double-click the column in the columns menu, find the right column header and then right click and New Formula Column ...
Every user has his favorite functions - and most likely they will not be in the right-click context menu which is used in the columns menu.
shampton82
Level VII
I agree and would go along with this post as well
https://community.jmp.com/t5/JMP-Wish-List/Column-options/idi-p/459643
Thank you for sharing this idea and for linking related requests!
