Allow right-click actions and broadcasting of Run Chart
The current implementation of Run Chart does not allow you to right-click the x-axis to copy axis settings, nor does it allow broadcasting x-axis settings to all run charts in the report. (see https://community.jmp.com/t5/Discussions/Easy-way-to-broadcast-x-axis-settings-in-Run-Chart/m-p/8967...)
When creating many run charts (on many process parameters), ideally one wants the x-axis to be the same for all of the charts.  This may include changing the format, increment, displaying grid lines, adding axis references.  While with a single chart you can edit the x-axis settings, you cannot copy those settings and broadcast them to other charts.
Why is this idea important?
This is a must have for efficient and consistent usage of JMP.
1 Comment
mia_stephens
Thanks @MathStatChem , adding to a previous request for this functionality.
