  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Allow right-click actions and broadcasting of Run Chart
The current implementation of Run Chart does not allow you to right-click the x-axis to copy axis settings, nor does it allow broadcasting x-axis settings to all run charts in the report. (see https://community.jmp.com/t5/Discussions/Easy-way-to-broadcast-x-axis-settings-in-Run-Chart/m-p/8967...)
When creating many run charts (on many process parameters), ideally one wants the x-axis to be the same for all of the charts.  This may include changing the format, increment, displaying grid lines, adding axis references.  While with a single chart you can edit the x-axis settings, you cannot copy those settings and broadcast them to other charts.
Why is this idea important?
This is a must have for efficient and consistent usage of JMP.
1 Comment
mia_stephens
Thanks @MathStatChem , adding to a previous request for this functionality.
