Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
When I do a contingency analysis, the numbers in the table are too big for the column and they end up overlapping. There is no way to adjust the size of the columns or the text formatting so that this doesn't happen.
I can confirm that this particular wish has been granted in the JMP 17 timeframe. JMP 17 will be available in fall 2022. To change the format of values in the Contingency Table, press Ctrl+Shift when you right-click the value in the table and select Format.
