  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Allow for Adjustment of Alpha Level of Parameter Estimates in Fit Curve and Nonlinear Platform
Current issue:
In the current implementation of JMP’s Fit Curve and Nonlinear platforms, the confidence intervals (CIs) for parameter estimates are fixed at a 95% confidence level. This limitation restricts users from aligning their statistical outputs with regulatory or methodological requirements that call for different confidence levels, such as 90%.
Example use case:
In the paper “Parallelism in Practice: Approaches to Parallelism in Bioassays” (Fleetwood et al., 2015), an equivalence test is used to assess parallelism by comparing the confidence interval of the slope difference to a pre-specified equivalence interval. The authors explicitly use a 90% confidence interval for this purpose. Since JMP only provides 95% CIs by default, users cannot directly replicate or validate this approach within JMP, limiting its utility for equivalence-based parallelism testing.
The approach is also detailed HERE.
Proposed enhancement:
Add in option to adjust the alpha level within the platforms.
Why is this idea important?
Value to users:
  • Regulatory alignment: Many bioassay and equivalence testing guidelines (e.g., USP <1034>) recommend or require 90% CIs.
2 Comments
Hello @Michelle_Ricci , thank you for posting your wish. We will investigate further your request.
Status changed to: Under Consideration
