Allow custom tableboxes to "make into combined data table"
I'd like it if we could make a combined data table from custom tables if they are carrying "the same" info like native reports do.
  For instance: allow all of these to somehow have the ages attached to them without having to hide columns and make custom "make into combined data table" functionalities
Names Default to Here(1);
dt = Open("$SAMPLE_DATA\Big Class.jmp");
Summarize(ages = by(:age));
hlb = hlistbox();
for(i=1, i<=nitems(ages), i++,
       rows = dt << Get Rows Where(char(Column(dt, "age")[]) == ages[i]);
       tblbox = Tablebox(
              StringColBox("Sex",
                     dt:sex[rows]
              StringColBox("Name",
                     dt:name[rows]
       hlb << append(
              OutlineBox(ages[i],
                     tblbox
new window("Test",
       hlb
3 Comments
gzmorgan0
Super User (Alumni)
@vince_faller ,
I am confused by this request. Make Combined Data Table grabs report window tables and combines them into a JMP Data Table.  Run the script below, right click on any sub table and select Make Combined Data Table and it works.  You also have a later Wish List request to set breaks for a table.   Given that request and this one, maybe a more JMP-like request is to add a By() option for TableBox(). Similar to a Bivariate with By that creates multiple Bivariates, it would create multiple TableBoxes.   Just my 2 cents.
idx = dt << new column("seq", numeric, << set each value(row()));
summarize(tgrp = By(:age), ibeg=minimum(idx), iend=maximum(idx));
new window("Row Borders",
	tblbox = VListBox(tablebox(
		NumberColBox("age", dt:age[ibeg[1]::iend[1]] ),
		StringColbox("Sex", dt:sex[ibeg[1]::iend[1]]),
		NumberColBox("Height", dt:height[ibeg[1]::iend[1]])
for(i=2, i<=nitems(tgrp), i++,
	tblbox << append(
		tablebox(
		NumberColBox("age", dt:age[ibeg[i]::iend[i]] ),
		StringColbox("Sex", dt:sex[ibeg[i]::iend[i]]),
		NumberColBox("Height", dt:height[ibeg[i]::iend[i]])
vince_faller
Super User (Alumni)
I wrote this a long time ago and just copied over.  Apparently it does work.  My bad.
Ryan_Gilmore
Community Manager
Status changed to: Archived
