%3CLINGO-SUB%20id%3D%22lingo-sub-779810%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EConsenti%20alla%20piattaforma%20di%20aggiornamento%20di%20creare%20nuove%20colonne%20se%20sono%20gi%C3%A0%20presenti%20nella%20tabella%20da%20aggiornare%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-779810%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3ECosa%20ti%20ha%20ispirato%20a%20richiedere%20questa%20lista%20dei%20desideri%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EUtilizzo%20della%20piattaforma%20di%20aggiornamento%20JMP%20e%20ricezione%20di%20messaggi%20di%20errore.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQuale%20miglioramento%20vorresti%20vedere%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ESe%20l'utente%20ha%20definito%20delle%20colonne%20da%20aggiungere%20e%20ha%20scelto%20di%20NON%20sostituire%20nessuna%20di%20quelle%20aggiunte%2C%20aggiungerle%20come%20nuove%20colonne%20con%20indice.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EErrore%3A%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3ENames%20Default%20To%20Here(1)%3B%0A%0Adt1%20%3D%20Open(%22%24SAMPLE_DATA%2FBig%20Class.jmp%22%2C%20Invisible)%3B%0Adt2%20%3D%20Open(%22%24SAMPLE_DATA%2FBig%20Class%20Families.jmp%22%2C%20Invisible)%3B%0A%0Adt1%20%26lt%3B%26lt%3B%20Update(%0A%09With(dt2)%2C%0A%09Match%20Columns(%3Aname%20%3D%20%3Aname)%2C%0A%09Add%20Columns%20from%20Update%20Table(%3Aage)%2C%0A%09Replace%20Columns%20in%20Main%20Table(None)%0A)%3B%0A%0AClose(dt1%2C%20no%20save)%3B%0AClose(dt2%2C%20no%20save)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3Ema%20vorrei%20finire%20con%20due%20colonne%20et%C3%A0%3A%20%3CSTRONG%3Eet%C3%A0%3C%2FSTRONG%3E%20originale%20e%20%3CSTRONG%3Eet%C3%A0%202%3C%2FSTRONG%3E%20appena%20creata%20dal%20dt2.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ERende%20l'utilizzo%20di%20Update%20pi%C3%B9%20flessibile%20senza%20dover%20ricorrere%20alla%20ridenominazione%20delle%20colonne%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-779810%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EAccesso%20ai%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EFusione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Consenti%20alla%20piattaforma%20di%20aggiornamento%20di%20creare%20nuove%20colonne%20se%20sono%20gi%C3%A0%20presenti%20nella%20tabella%20da%20aggiornare%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-798032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Consenti%20alla%20piattaforma%20di%20aggiornamento%20di%20creare%20nuove%20colonne%20se%20sono%20gi%C3%A0%20presenti%20nella%20tabella%20da%20aggiornare%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-798032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Epotresti%20usare%20Tables%2FJoin%20invece%20di%20Tables%2FUpdate.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EJoin%20offre%20la%20possibilit%C3%A0%20di%20scegliere%20tra%20l'unione%20delle%20colonne%20e%20il%20mantenimento%20di%20entrambe.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Allow Update platform to create new columns if they already exist in the table to be updated
Using JMP's Update platform and getting error messages.
If user has defined columns to be added and chose NOT to replace any of those added columns, add them as new columns with index.
Error:
Names Default To Here(1);
dt1 = Open("$SAMPLE_DATA/Big Class.jmp", Invisible);
dt2 = Open("$SAMPLE_DATA/Big Class Families.jmp", Invisible);
dt1 << Update(
	With(dt2),
	Match Columns(:name = :name),
	Add Columns from Update Table(:age),
	Replace Columns in Main Table(None)
Close(dt1, no save);
Close(dt2, no save);
but I would like to end up with two age columns: original age and newly created age 2 from the dt2.
Why is this idea important?
Makes using Update more flexible without having to rely on renaming columns
2 Comments
hogi
Level XII
you could use Tables/Join instead of Tables/Update.
Join provides an option to choose between merging columns and keeping both columns.
