%3CLINGO-SUB%20id%3D%22lingo-sub-664657%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EConsenti%20a%20TableBox%20di%20avere%20righe%20di%20altezze%20variabili%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-664657%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3ECosa%20mi%20ha%20ispirato%20questa%20richiesta%20di%20lista%20dei%20desideri%3F%3C%2FSTRONG%3E%20Utilizzo%20TableBox%20per%20simulare%20una%20ListBox%20ma%20con%20formattazione%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQuale%20miglioramento%20vorresti%20vedere%3F%3C%2FSTRONG%3E%20Vorrei%20che%20le%20righe%20di%20TableBox%20non%20fossero%20tutte%20forzate%20alla%20stessa%20altezza%20esatta%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3E%20Considerate%20un%20TableBox%20con%20un%20solo%20figlio%20allegato%2C%20un%20ColBox%20con%20vari%20elementi.%20Il%20TableBox%20ha%20una%20sola%20colonna%2C%20non%20c'%C3%A8%20motivo%20di%20forzare%20tutte%20le%20righe%20ad%20avere%20la%20stessa%20altezza%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EConsiderate%20il%20seguente%20JSL%3A%20sarebbe%20bello%20se%20la%20prima%20riga%20potesse%20essere%20dimensionata%20in%20base%20al%20suo%20contenuto%2C%20non%20in%20base%20al%20contenuto%20della%20seconda%20riga.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3ENames%20Default%20To%20Here(%201%20)%3B%0ANew%20Window(%20%22Mountains%22%2C%0A%09tb%20%3D%20Table%20Box(%0A%09%09Col%20Box(%20%22Heights%22%2C%0A%09%09%09Text%20Box(%20%22Short%20Row%22%20)%2C%0A%09%09%09Spacer%20Box(%20Size(%20100%2C%20100%20)%2C%20%26lt%3B%3CBACKGROUND%20color%3D%22%22%3E%3C%2FBACKGROUND%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CCODE%20class%3D%22%20language-jsl%22%3E%20%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3CCODE%20class%3D%22%20language-jsl%22%3E%20%3C%2FCODE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CCODE%20class%3D%22%20language-jsl%22%3E%3CLINGO-LABS%20id%3D%22lingo-labs-664657%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EOrganizzazione%20dei%20contenuti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3C%2FCODE%3E
Allow TableBox to have rows of variable heights
What inspired this wish list request? I use TableBox to simulate a ListBox but with formatting
What is the improvement you would like to see? I would like to see TableBox rows not all be forced to the exact same height
Why is this idea important? Consider a TableBox with only one attached child -- a ColBox with various elements.  The TableBox has only one column -- there is no reason to force all rows to have the same height
Consider the following JSL -- it would be nice if the first row could be sized to it's content, not to the content of the second row.
Names Default To Here( 1 );
New Window( "Mountains",
	tb = Table Box(
		Col Box( "Heights",
			Text Box( "Short Row" ),
			Spacer Box( Size( 100, 100 ), <<Background Color( "Blue" ) )
