  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Allow Action Recorder to use simple variable names as references
Currently Action Recorder creates fairly non-robust code by using table names and such. New Workflow Builder is able to offer reference replacements but I would like to go a bit further and have an option in which Action Recorder would use variable names. These should be configurable by user. Also namespace should be used in this case, either some specific one or here (add Names Default To Here(1); to top of script)
Below is fairly simple example created using Big Class and Enhanced Log
// Open Data Table: Big Class.jmp
// → Data Table("Big Class")
Open("/C:/Program Files/SAS/JMPPRO/16/Samples/Data/Big Class.jmp");
// New formula column: Log[weight+1]
Data Table("Big Class") << New Formula Column(
	Operation(Category("Log"), "Log x+1"),
	Columns(:weight)
// New formula column: Random Uniform
	Operation(Category("Random"), "Random Uniform"),
	Columns(:sex, :height)
// Report snapshot: Big Class - Graph Builder
Data Table("Big Class") << Graph Builder(
	Size(528, 448),
	Show Control Panel(0),
	Variables(X(:sex), Y(:"Log[weight+1]"n)),
	Elements(Points(X, Y, Legend(4)))
It would be nice if this could be written in log as (this won't work as it seems like << New Formula Column doesn't return reference to the column like << New Column does, but the idea is still the same)
dt_1 = Open("/C:/Program Files/SAS/JMPPRO/16/Samples/Data/Big Class.jmp");
col_1 = dt_1 << New Formula Column(
	Columns(:weight)
col_2 = dt_1 << New Formula Column(
rep_1 = dt_1 << Graph Builder(
	Size(528, 448),
	Variables(X(:sex), Y(col_1)),
And in this example dt_, col_ and rep_ are the variable name prefixes user has chosen for these specific object types.
This should make auto-generated scripts a bit more robust
1 Comment
Thank you for submitting this request and providing an example! We have documented this and will review your idea @jthi
