%3CLINGO-SUB%20id%3D%22lingo-sub-423900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAjoutez%20un%20test%20de%20sup%C3%A9riorit%C3%A9%20aux%20analyses%20unidirectionnelles%20indiquant%20la%20probabilit%C3%A9%20d'%C3%AAtre%20sup%C3%A9rieur%20par%20diff%C3%A9rentes%20marges.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-423900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAjoutez%20un%20test%20pour%20produire%20des%20valeurs%20p%20de%20tests%20de%20sup%C3%A9riorit%C3%A9%20sur%20une%20plage%20de%20distances%20et%20affichez-les%20dans%20un%20tableau%20ou%20un%20graphique%20comme%20indiqu%C3%A9%20ci-dessous.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ih_1-1633695166276.png%22%20style%3D%22width%3A%20842px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ih_1-1633695166276.png%22%20style%3D%22width%3A%20842px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36419i22C41861B2AEA26C%2Fimage-dimensions%2F842x438%3Fv%3Dv2%22%20width%3D%22842%22%20height%3D%22438%22%20role%3D%22button%22%20title%3D%22ih_1-1633695166276.png%22%20alt%3D%22ih_1-1633695166276.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPrenons%20un%20essai%20dans%20lequel%20un%20changement%20de%20processus%20est%20apport%C3%A9.%20Les%20r%C3%A9sultats%20sont%20compar%C3%A9s%20aux%20performances%20actuelles%20et%20le%20test%20d%C3%A9termine%20que%20le%20processus%20a%20%C3%A9t%C3%A9%20am%C3%A9lior%C3%A9%20(la%20moyenne%20a%20%C3%A9t%C3%A9%20d%C3%A9cal%C3%A9e)%20avec%20une%20valeur%20p%20de%200%2C05%20et%20un%20test%20de%20sup%C3%A9riorit%C3%A9%20dans%20JMP%2017%20indique%20que%20la%20moyenne%20a%20%C3%A9t%C3%A9%20d%C3%A9cal%C3%A9e%20d'au%20moins%200%2C01%20avec%20une%20valeur%20p%20de%200%2C12%2C%20mais%20ni%20l%E2%80%99un%20ni%20l%E2%80%99autre%20ne%20raconte%20toute%20une%20histoire.%20Pour%20prendre%20une%20d%C3%A9cision%20%C3%A9clair%C3%A9e%2C%20nous%20aimerions%20conna%C3%AEtre%20des%20informations%20telles%20que%26nbsp%3B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E5%26nbsp%3B%25%20de%20chances%20que%20le%20processus%20reste%20le%20m%C3%AAme%20ou%20%3CEM%3Es'aggrave%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3E90%26nbsp%3B%25%20de%20chances%20que%20le%20processus%20s'am%C3%A9liore%20d'au%20moins%200%2C01%3C%2FLI%3E%0A%3CLI%3E50%26nbsp%3B%25%20de%20chances%20que%20le%20processus%20s'am%C3%A9liore%20d'au%20moins%200%2C006%3C%2FLI%3E%0A%3CLI%3E5%26nbsp%3B%25%20de%20modification%20du%20processus%20am%C3%A9lior%C3%A9%20d'au%20moins%200%2C011%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EVoici%20un%20article%20avec%20deux%20m%C3%A9thodes%20potentielles%20pour%20calculer%20ces%20valeurs%26nbsp%3B%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FCompare-means-test-graph-probability-by-difference-in-means%2Fm-p%2F419514%23U419514%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3ETest%20de%20comparaison%20des%20moyennes%26nbsp%3B%3A%20graphique%20de%20probabilit%C3%A9%20par%20diff%C3%A9rence%20de%20moyennes%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-423900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAnalyse%20et%20mod%C3%A9lisation%20des%20donn%C3%A9es%20de%20base%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Add superiority test to oneway analyses indicating the probability of being superior by different margins.
Add a test to produce p values of superiority tests at a range of distances and output those to a table or graph as shown below.
Consider a trial where a process change is made.  Results are compared with current performance and a t test determines that the process was improved (the mean shifted) with a p-value of 0.05 and a superiority test in JMP 17 indicates that the mean shifted by at least 0.01 with a p value of 0.12, but neither tells a whole story.  To make an informed decision, we would want to know information like:
  • 5% chance the process stayed the same or got worse
  • 90% chance the process improved by at least 0.01
  • 50% chance the process improved by at least 0.006
  • 5% change the process improved by at least 0.011
Here is a post with two potential methods of calculating these values:
Compare means test: graph probability by difference in means
