%3CLINGO-SUB%20id%3D%22lingo-sub-664753%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAggiungi%20%22Apri%20cartella%20di%20inclusione%22%20al%20menu%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-664753%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3ECosa%20ha%20ispirato%20questa%20richiesta%20di%20lista%20dei%20desideri%3F%3CI%3E%20%3C%2FI%3E%3C%2FSTRONG%3ESemplifica%20l'accesso%20al%20file%20stesso%20in%20Esplora%20risorse%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EQual%20%C3%A8%20il%20miglioramento%20che%20vorresti%20vedere%3F%3C%2FSTRONG%3E%20Aggiungi%20%22Apri%20cartella%20di%20chiusura%22%20al%20menu%20File%20in%20modo%20che%20da%20una%20tabella%20di%20dati%20l'utente%20possa%20aprire%20rapidamente%20la%20cartella%20che%20contiene%20quel%20file.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3CI%3E%20%3C%2FI%3E%3C%2FSTRONG%3EMigliora%20l'accessibilit%C3%A0%20degli%20output%20JMP.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-664753%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EOrganizzazione%20dei%20contenuti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EAccesso%20ai%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-664820%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Aggiungi%20%22Apri%20cartella%20di%20inclusione%22%20al%20menu%20File%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-664820%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EFino%20a%20quando%20la%20funzione%20non%20sar%C3%A0%20disponibile%2C%20potresti%20utilizzare%3A%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Edt%20%3D%20current%20data%20table()%3B%0Afile_path%3Ddt%20%26lt%3B%3CGET%20path%3D%22%22%3E%3C%2FGET%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "Open Enclosing Folder" to File menu
What inspired this wish list request?  Make it easier to access the file itself in Windows Explorer
What is the improvement you would like to see?  Add "Open Enclosing Folder" to the File menu so that from a data table, the user can quickly open the folder holding that file.
Why is this idea important?  Improves accessibility of JMP outputs.
1 Comment
hogi
Level XII
Till the function is available, you could use:
dt = current data table();
file_path=dt <<Get Path;
filelength = Length( Word( -1, file_path, "\/" ) );
pathlength = Length( file_path) - filelength - 1;
path = Substr( file_path, 1, pathlength );
open(path)
