Add option to use cache when using column switcher and changing back to already calculated columns
Having to write my own tooling on top of existing JMP platforms to make sure JMP functions fast. In this case, calculations which can potentially take a long time (MSA) and users might have to go back-and-forth between different columns and it will trigger re-calculations.
Implement cache for column switcher which would be utilized if there has been no changes to data. For example, in the following script if you change columns and come back to columns which you have already visited, JMP will recalculate the values which will take time. I would like to JMP to have some sort of memory of the already calculate columns which it would use if there has been no changes to warrant new calculation. Also, give an option to "pre-calculate" all columns in column switcher.
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
dist = dt << Distribution(
	Continuous Distribution(
		Column(:NPN1),
		Always use column properties(1),
		Process Capability(0),
		Fit Normal(Goodness of Fit(1))
	Histograms Only,
	Column Switcher(
		:NPN1,
		{:NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1,
		:INM1, :INM2, :VPM1, :VPM2, :VPM3, :PMS1, :SNM1, :SPM1, :NPN5, :EP2, :ZD6,
		:PBA, :PLG, :CAP, :PBA3, :PLG2, :PNP5, :NPN6, :PNP6, :PNP7, :NPN7, :PNP8,
		:IVP3, :IVP4, :IVP5, :IVP6, :PNP9, :NPN8, :NPN9, :IVP7, :NPN10, :N_1, :PBA1,
		:WPR1, :B10, :PLY10, :VBE210, :VTN210, :VTP210, :SIT2, :SIT3, :INV2, :INV3,
		:INV4, :INV5, :FST1, :FST2, :RES1, :RES2, :PNM1, :PPM1, :FNM1, :FPM1, :FST3,
		:FST4, :RES3, :RES4, :A1, :B1, :A2N, :A2P, :A2P1, :IVP8, :IVP9, :DE_H1,
		:NF_H1, :ESM1, :ESM2, :ESP1, :YFU1, :VPM4, :PBA2, :PBB1, :LYA1, :LYB1, :DEM1,
		:DEP1, :NFM1, :PLY1, :VDP1, :VDP2, :SNW1, :RSP2, :PLY2, :RSP1, :VDP3, :PBL1,
		:PLG1, :VDP4, :SPW1, :VIA1, :INM3, :VPM5, :VPM6, :INM4, :VPM7, :M1_M1,
		:M2_M2, :P1_P1, :E2A1, :E2B1, :NPN11, :IVP10, :PNP10, :INM5, :VPM8, :VPM9,
		:INM6, :VPM10, :N2A1, :N2B1, :NM_L1, :P2A1, :P2B1, :PM_L1, :P1, :M1}
Very quickly made example, but it is able to demonstrate how much snappier this is. Note: if you enable pre_calculate the script will be quite slow as the fitting isn't too fast in JMP but there is of course reward in the end, as can very quickly go through all reports after (let analysis run, go get a glass of water, come back and have a snappy way of viewing results)
numcols = dt << Get Column Names("Numeric", "String");
pre_calculate = 0;
aa_memory = Associative Array(numcols, Repeat({Empty()}, N Items(numcols)));
nw = New Window("",
	H List Box(
		lb = List Box(numcols, << Set Max Selected(1)),
		dist_collector = V List Box()
lb << Set Function(Function({this},
	sel = this << get selected;
	If(N Items(sel) == 0,
		return(0);
		sel = sel[1];
	If(Is Empty(aa_memory[sel]),
		dist_collector << Append(
			aa_memory[sel] = V List Box(dt << Distribution(
					Column(Eval(sel)),
				Histograms Only
	objs = Filter Each({obj}, aa_memory << get values,
		!Is Empty(obj) & obj != aa_memory[sel];
	objs << Visibility("Collapse");
	aa_memory[sel] << Visibility("Visible");
	wait(0);
If(pre_calculate,
	nw << Show Window(0);
	For(i = 1, i <= N Items(aa_memory), i++,
		lb << Set Selected(i, 1, run script(1));
	nw << Show Window(1);
	lb << Set Selected(1, 1, run script(1));
wait(0);
Why is this idea important?
Makes it easier to swap between different columns when using column switcher without having to wait for JMP to re-calculate everything.
1 Comment
Sarah-Sylvestre
Level V
Thank you for taking the time to submit this request and providing examples.
