Add normalization and robust statistical functions (and matrix functions)
Add new Col statistical functions:
Also add as many of these as possible to Matrix operations if they are missing.
Most of these could already be implemented fairly easily by using existing statistical functions, but I would much rather have them as normal functionality in JMP (native implementation could also be faster?). In my opinion, these are very useful and powerful functions (like are all other Statistical Col functions).
Example functions (might include mistakes):
View more...
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Big Class.jmp");
// add outlier for M
dt << Add Rows({name = "OUTLIER", age = 1, sex = "M", height = 500, weight = 500});
// add limits
dt << New Column("LSL", Numeric, Continuous, << Set Each Value(50));
dt << New Column("USL", Numeric, Continuous, << Set Each Value(60));
dt << New Column("ColMean_height", Numeric, Continuous, Formula(
	Col Mean(:height, :sex, Excluded())
dt << New Column("ColMedian_height", Numeric, Continuous, Formula(
	Col Median(:height, :sex, Excluded())
dt << New Column("ColStdDev_height", Numeric, Continuous, Formula(
	Col Std Dev(:height, :sex, Excluded())
dt << New Column("ColIQR_height", Numeric, Continuous, Formula(
	Col Quantile(:height, 0.75, :sex, Excluded()) - Col Quantile(:height, 0.25, :sex, Excluded())
dt << New Column("ColStandardize_height", Numeric, Continuous, Formula(
	Col Standardize(:height, :sex, Excluded())
// Example https://scikit-learn.org/stable/modules/generated/sklearn.preprocessing.RobustScaler.html
// using IQR here, but might be good idea to be able to change the quantiles (default to IQR)
dt << New Column("ColStandardizeRobust_height", Numeric, Continuous, Formula(
	(:height - Col Median(:height, :sex, Excluded())) / :ColIQR_height
// https://en.wikipedia.org/wiki/Feature_scaling#Rescaling_(min-max_normalization)
dt << New Column("ColNormalize_01", Numeric, Continuous, Formula(
	0 + (:height - Col Min(:height, :sex, Excluded())) / (Col Max(:height, :sex, Excluded()) - Col Min(:height, :sex, Excluded()))
dt << New Column("ColNormalize_11", Numeric, Continuous, Formula(
	-1+(:height - Col Mean(:height, :sex, Excluded()))*(1-(-1)) / (Col Max(:height, :sex, Excluded()) - Col Min(:height, :sex, Excluded()))
dt << New Column("ColNormalize_limits", Numeric, Continuous, Formula(
	ColMin(:LSL, :sex)+(:height - Col Mean(:height, :sex, Excluded()))*(ColMax(:USL, :sex)-(ColMin(:LSL, :sex))) / (Col Max(:height, :sex, Excluded()) - Col Min(:height, :sex, Excluded()))
// maybe even Robust Sigma, divider would default to 1.35
// http://www.aecouncil.com/Documents/AEC_Q001_Rev_D.pdf
// and robust limits, sigma multiplier defaulting to 6
9 Comments
SamGardner
Level VII
Thank you for the list of specific examples.  We may take this under consideration for a future release.
hogi
Level XII
robust sigma was already requested some years ago:
https://community.jmp.com/t5/JMP-Wish-List/Robust-Means-and-Standard-Deviation-functions-in-JSL-and-... (October 2024: 17 kudos)
hogi
Level XII
Another aggregation that is already available in the Table summary mneu, but not as a Col ... Formula is Median Absolute Deviation (MAD):
https://en.wikipedia.org/wiki/Median_absolute_deviation
hogi
Level XII
amazing: the amount of aggregation functions for header statistics!
hogi
Level XII
related wishes:
Col N Categories (October 2024: 15 Kudos)
Add dense ranking to Ranking Tie and Col Rank functions (October 2024: 9 Kudos)
hogi
Level XII
+ Col MAD (Median Absolute deviation)
