Add function which can be universally used to check if object/variable is empty/missing
JMP has multiple different ways to indicate if values are empty, missing or null and functions/operations might return different types when they have no values when compared to when they do have (and in Python the "pythonic" way would be just to check value in If-statement as the objects will be false Built-in Types/Truth Value Testing).
More universal JSL function to check if value is empty/missing/null/has no value. Below is one example for the function (hopefully others have additional ideas):
Names Default To Here(1);
Is None = function({obj, keep_zero = 1}, {Default Local},
	/*"""Attempt to check if object is None (Empty(), ., 0, "", {}, [], [=>], [](0,1)...
	Args:
		obj: object to check
	Returns:
		int: 0 if non-zero and 1 if zero
	Examples:
		>> show(Is None([1 => 2]));
			Is None([1 => 2]) = 0;
		>> show(Is None(Associative Array()));
			Is None(Associative Array()) = 1;
	cur_type = Type(obj);
	return(
		If(Contains({"List", "Matrix", "Associative Array"}, cur_type), // check items in list, matrix and associative array
			!N Items(obj);
		, cur_type == "String",
			!Length(obj); // check string length, Is Missing() should also work
		, Contains({"Integer", "Number"}, cur_type),
			If(IsMissing(obj),
				1
			, keep_zero & obj == 0,
				1
				0
		, cur_type == "Empty",
			1;
			0;
Print("Zeros:");
show(Is None({"a"}));
show(Is None([1]));
show(Is None(1));
show(Is None("a"));
Write("\!N");
Print("Ones:");
show(Is None({}));
show(Is None([]));
show(Is None(0));
show(Is None(""));
show(Is None(.));
show(Is None(Empty()));
Why is this idea important?
Makes it easier to build comparisons without guessing which check should be implemented this time (IsMissing(), Is Empty(), N Items() > 0, Zero Or Missing()...)
1 Comment
Craige_Hales
